BryceMattia
#1 Posted : Friday, January 5, 2018 11:09:45 PM(UTC)
BryceMattia
I'm not sure if it's because my webcam isn't high enough quality, but every time I try to use the chromekeying feature with my green screen I can never get a clean key. The edges of my body and head are always fuzzy. I'm using a LogitechC920 if that matters. Has anyone else had a similar issue?
cbpayne
#2 Posted : Saturday, January 6, 2018 5:12:23 AM(UTC)
cbpayne
LogiTechC920 should be fine
Check lighting (I use two lights beside me (out of shot) pointing at green screen behind me; and one light in from of me pointing at me)
Make adjustments to the options in vMix (filter etc)
Use Logitech webcam software and check settings; color balances etc (do this before connecting to vMix)
Joeboe
#3 Posted : Saturday, January 6, 2018 6:36:43 AM(UTC)
Joeboe
Proper lighting is the key to chromakeying...there are video and other tutorials on line about it, so do a google search.....The green screen has to be the right tone, the lighting has to be consistant and evenly spread, and the camera should have a manually set white balance for better control.....just do a search for chromakey online, and you should get a lot of stuff on the subject...
BryceMattia
#4 Posted : Saturday, January 6, 2018 8:27:37 PM(UTC)
BryceMattia
I played around with the lighting and it worked 100 times better. Thank you so much!
rowby
#5 Posted : Sunday, January 7, 2018 2:39:02 PM(UTC)
rowby
Also try to separate the green screen as far as possible from you. You don't want your shadow showing on the green screen.
Rowby
thanks 1 user thanked rowby for this useful post.
mjgraves on 1/8/2018(UTC)
Joeboe
#6 Posted : Sunday, January 7, 2018 3:49:29 PM(UTC)
Joeboe
here is a tip on lighting
.....and here is some green screen video....
another chromakey video....
Guest (4)
