I'm not sure if it's because my webcam isn't high enough quality, but every time I try to use the chromekeying feature with my green screen I can never get a clean key. The edges of my body and head are always fuzzy. I'm using a LogitechC920 if that matters. Has anyone else had a similar issue?
Joined: 11/25/2017(UTC) Posts: 6  Location: Australia Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
LogiTechC920 should be fine Check lighting (I use two lights beside me (out of shot) pointing at green screen behind me; and one light in from of me pointing at me) Make adjustments to the options in vMix (filter etc) Use Logitech webcam software and check settings; color balances etc (do this before connecting to vMix)
Proper lighting is the key to chromakeying...there are video and other tutorials on line about it, so do a google search.....The green screen has to be the right tone, the lighting has to be consistant and evenly spread, and the camera should have a manually set white balance for better control.....just do a search for chromakey online, and you should get a lot of stuff on the subject...
I played around with the lighting and it worked 100 times better. Thank you so much!
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Also try to separate the green screen as far as possible from you. You don't want your shadow showing on the green screen.
Rowby
 1 user thanked rowby for this useful post.
here is a tip on lighting .....and here is some green screen video.... another chromakey video....
