Henny
#1 Posted : Thursday, August 29, 2013 4:09:24 PM(UTC)
Henny
Hi all,
I'm looking at a way of using a webpage as an input without using a second pc with screen capture.
one idea I had was to use the Powerpoint input and use a plugin to embed the webpage in the powepoint but it looks like the way vmix displays powerpoints it kills any plugins.
Can any one else think of a way of showing a webpage or whats the chances of having a webpage input added to vmix.
cheers
ian
vmixsupport
#2 Posted : Thursday, August 29, 2013 8:04:23 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Hi Ian,
Thought I'd also point out that you don't necessarily need a second PC as you can run the desktop capture program from the same PC to input the webpage. This would probably only suit if you already have two monitors to easily navigate between.
Similar Topics
Unable to use keyboard when using a webpage as input (General Discussion)
by Shalem 6/18/2016 10:09:08 PM(UTC)
