Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Hi all,
I'm looking at a way of using a webpage as an input without using a second pc with screen capture.
one idea I had was to use the Powerpoint input and use a plugin to embed the webpage in the powepoint but it looks like the way vmix displays powerpoints it kills any plugins.
Can any one else think of a way of showing a webpage or whats the chances of having a webpage input added to vmix.
cheers
ian
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 241 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 159 time(s) in 72 post(s)
Hi Ian, Thought I'd also point out that you don't necessarily need a second PC as you can run the desktop capture program from the same PC to input the webpage. This would probably only suit if you already have two monitors to easily navigate between.
