livepad
#1 Posted : Sunday, December 31, 2017 7:25:22 AM(UTC)
livepad
Was thanked: 46 time(s) in 32 post(s)
Folks.
Just a quick update to let you all know that the NDI HX support-fest continues on macOS.
Latest addition is an update to Sienna's NDI Outlet app (which converts NDI to SDI/HDMI via BlackMagic Design interfaces).
As with the previous HX versions, NDI HX support has been embedded into the app meaning there is no need to install a separate NDI HX driver.
NDI Outlet provide low latency conversion between NDI & NDI HX and SDI/HDMI including support for SDI Fill and Key with Alpha Keyed NDI sources. NDI Outlet also performs pillarbox/letterbox conversion of non-16x9 NDI Sources when converting to SDI/HDMI
Available now in the app store
A Demo version is available from the website
