NDI
NDI HX Support for Sienna NDI Outlet for macOS
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
Folks. Just a quick update to let you all know that the NDI HX support-fest continues on macOS. Latest addition is an update to Sienna's NDI Outlet app (which converts NDI to SDI/HDMI via BlackMagic Design interfaces). As with the previous HX versions, NDI HX support has been embedded into the app meaning there is no need to install a separate NDI HX driver. NDI Outlet provide low latency conversion between NDI & NDI HX and SDI/HDMI including support for SDI Fill and Key with Alpha Keyed NDI sources. NDI Outlet also performs pillarbox/letterbox conversion of non-16x9 NDI Sources when converting to SDI/HDMI Available now in the app storeA Demo version is available from the website
NDI
