jiangjinqiang
#1 Posted : Thursday, December 7, 2017 10:58:46 PM(UTC)
jiangjinqiang
Hi,admin
MIDI can hot plug in Windows 10?
https://blogs.windows.co...ancements-in-windows-10/
The API plugs in nicely with the device enumeration and watcher APIs in UWP, making it easy to detect hot plug/unplug of devices while your app is running.
Here’s a simple way to get a list of MIDI devices and their IDs, using C#:
using Windows.Devices.Midi;
using Windows.Devices.Enumeration;
private async void ListMidiDevices()
// Enumerate Input devices
var deviceList = await DeviceInformation.FindAllAsync(
MidiInPort.GetDeviceSelector());
foreach (var deviceInfo in deviceList)
System.Diagnostics.Debug.WriteLine(deviceInfo.Id);
System.Diagnostics.Debug.WriteLine(deviceInfo.Name);
System.Diagnostics.Debug.WriteLine("----------");
// Output devices are enumerated the same way, but
// using MidiOutPort.GetDeviceSelector()
