MIDI hot plug in Windows 10
Hi,admin MIDI can hot plug in Windows 10? https://blogs.windows.co...ancements-in-windows-10/The API plugs in nicely with the device enumeration and watcher APIs in UWP, making it easy to detect hot plug/unplug of devices while your app is running. Here’s a simple way to get a list of MIDI devices and their IDs, using C#: using Windows.Devices.Midi; using Windows.Devices.Enumeration; ... private async void ListMidiDevices() { // Enumerate Input devices var deviceList = await DeviceInformation.FindAllAsync( MidiInPort.GetDeviceSelector()); foreach (var deviceInfo in deviceList) { System.Diagnostics.Debug.WriteLine(deviceInfo.Id); System.Diagnostics.Debug.WriteLine(deviceInfo.Name); System.Diagnostics.Debug.WriteLine("----------"); } // Output devices are enumerated the same way, but // using MidiOutPort.GetDeviceSelector() }
