wendell
#1 Posted: : Wednesday, November 29, 2017 4:49:55 AM(UTC)
wendell
Hello, Everyone! After longtime replace my older PC with a new one for next 5 year. My budget is $2000. So guys what gaming pc are you using and what are the specs of your pc. I would choose some spec which is mention below but I am totally confused to choose a case for PC. Please Help me to choose a case. is Corsair Crystal Series 570X RGB perfect?
ASUS MAXIMUS IX FORMULA LGA1151 DDR4 DP HDMI M.2 Z270 ATX Motherboard ($387.89)
Intel 7th Gen Intel Core Desktop Processor i7-7700K ($329.89)
Storage: 240GB SSD ($74.99) and WD Black 750GB ($57.99)
Corsair CMPSU-400CX 400-Watt CX Series 80 Plus (39.99)
Memory: 32GB Corsair Vengence DDR4 ($369)
EVGA GeForce GTX 1080 Founders Edition, 8GB GDDR5X, LED ($570.49)
Thanks In Advance
Ittaidv
#2 Posted : Wednesday, November 29, 2017 3:23:21 PM(UTC)
Ittaidv
All looking good, just one advice for the motherboard: if you go for one that features a plx chip, you might squeeze a bit more performance out of it. By buying a better motherboard from the start, you avoid replacing it along the way.
Peter B
#3 Posted : Wednesday, November 29, 2017 11:00:32 PM(UTC)
Peter B
I would up the power supply to at least 600w.
1080's usually recommend 500w.
wendell
#4 Posted : Thursday, November 30, 2017 8:39:11 AM(UTC)
wendell
Can you share with me what supply are you use?
wendell
#5 Posted : Thursday, November 30, 2017 8:42:39 AM(UTC)
wendell
Alright! Share with me what motherboard you suggest and is Corsair Crystal Series 570X RGB perfect or choose some other case?
Peter B
#6 Posted : Thursday, November 30, 2017 6:28:43 PM(UTC)
Peter B
It's 1000w, good to over rate it so it never runs at full capacity.
I can upgrade anything and not worry about the psu.
alicehoward13
#7 Posted : Wednesday, December 2, 2020 9:06:33 PM(UTC)
alicehoward13
Germany
Great Content. You must also check Best Battle Royale Games
