Hello, Everyone! After longtime replace my older PC with a new one for next 5 year. My budget is $2000. So guys what gaming pc are you using and what are the specs of your pc. I would choose some spec which is mention below but I am totally confused to choose a case for PC. Please Help me to choose a case. is Corsair Crystal Series 570X RGB perfect?
ASUS MAXIMUS IX FORMULA LGA1151 DDR4 DP HDMI M.2 Z270 ATX Motherboard ($387.89) Intel 7th Gen Intel Core Desktop Processor i7-7700K ($329.89) Storage: 240GB SSD ($74.99) and WD Black 750GB ($57.99) Corsair CMPSU-400CX 400-Watt CX Series 80 Plus (39.99) Memory: 32GB Corsair Vengence DDR4 ($369) EVGA GeForce GTX 1080 Founders Edition, 8GB GDDR5X, LED ($570.49)
Thanks In Advance
You have been a member since:: 12/19/2013(UTC) Views messages in topic : 602   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
All looking good, just one advice for the motherboard: if you go for one that features a plx chip, you might squeeze a bit more performance out of it. By buying a better motherboard from the start, you avoid replacing it along the way.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
I would up the power supply to at least 600w. 1080's usually recommend 500w.
Peter B wrote:I would up the power supply to at least 600w. 1080's usually recommend 500w. Can you share with me what supply are you use?
Ittaidv wrote:All looking good, just one advice for the motherboard: if you go for one that features a plx chip, you might squeeze a bit more performance out of it. By buying a better motherboard from the start, you avoid replacing it along the way. Alright! Share with me what motherboard you suggest and is Corsair Crystal Series 570X RGB perfect or choose some other case?
wendell wrote:Peter B wrote:I would up the power supply to at least 600w. 1080's usually recommend 500w. Can you share with me what supply are you use? It's 1000w, good to over rate it so it never runs at full capacity. I can upgrade anything and not worry about the psu.
Joined: 12/2/2020(UTC) Posts: 1  Location: Berlin, Germany
