good day guyz. Please i have a blackmagic intensity shuttle with Usb 3.0 and with the latest desktop capture for blackmagic. do the to work together. thanks
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 69 Location: Canada
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
The BMD Intensity Shuttle USB 3.0 has not proven itself to be reliable and does not make the list of Supported Capture Devices (only the Intensity Shuttle Thunderbolt). You may be lucky and have it function fine for you, but it is not a supported device for use with vMix vMixGreg
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
I've pretty much given up on using my Intensity Shuttle USB... way way to tempermental.
