Recordings split into segments
Joined: 9/29/2017(UTC) Posts: 16 Location: Surrey, BC
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Hello - I am still a newbie. I have a windows 10 and the VMix 20. I want to record my artwork via videocam. I have set the recording cog so that it is on AVI, size 1920x1080, frame rate 29.97, Codec MJPEG, File Format AVI. When recording it splits into multiple segments. Is there a way to prevent this from splitting? If not, what I can use to mend the clips together so that it is one smooth video?
TIA, Liz
Joined: 2/14/2016(UTC) Posts: 117  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
Change the setting "new file every x minutes" to "none"...
Not very smart to do, because is something happens during writing of the file you will losse the complete recording instead of x minutes only.
There are tools to append several AVI files into 1 file, just use google... I record in MP4-format and use MP4box to append all files when needed!
 1 user thanked Mari for this useful post.
