stampersplus
#1 Posted : Monday, November 20, 2017 9:07:58 PM(UTC)
stampersplus
Hello - I am still a newbie. I have a windows 10 and the VMix 20. I want to record my artwork via videocam. I have set the recording cog so that it is on AVI, size 1920x1080, frame rate 29.97, Codec MJPEG, File Format AVI. When recording it splits into multiple segments. Is there a way to prevent this from splitting? If not, what I can use to mend the clips together so that it is one smooth video?
TIA, Liz
Mari
#2 Posted : Tuesday, November 21, 2017 1:11:27 AM(UTC)
Mari
Netherlands
Change the setting "new file every x minutes" to "none"...
Not very smart to do, because is something happens during writing of the file you will losse the complete recording instead of x minutes only.
There are tools to append several AVI files into 1 file, just use google... I record in MP4-format and use MP4box to append all files when needed!
thanks 1 user thanked Mari for this useful post.
stampersplus on 11/21/2017(UTC)
