mazlani
#1 Posted : Wednesday, November 15, 2017 2:16:16 AM(UTC)
mazlani
Hi.
I'm using Vmix 4K. 3 outputs(3 different content) to 3 LED screen in an indoor stadium....center hung, under belly and fascia ribbon. See enclosed photo.
Currently, this is how we switch input to the 3 output:
Center hung - Output1....program output
Fascia Ribbon - Output2..manually select input or shortcut key
Under belly - External2..manually select input or shortcut key
The 3 screen has different content but with the same theme.
Say sponsor A:
Output1 - advertisement A1
Output2 - advertisement A2
External -advertisement A3
So when sponsor A play.....all 3 advertisement(A1, A2 n A3) goes to the output.
We used shortcut key to change the output.
Now we have 5 sponsor....need to create 5 of the above. 5 shortcut key.
Question....is there somehow we can create a playlist or script to loop the 5 sponsors for 3 outputs?
Appreciate you help.
Thank you in advance.
mazlani attached the following image(s):
