Hi. I'm using Vmix 4K. 3 outputs(3 different content) to 3 LED screen in an indoor stadium....center hung, under belly and fascia ribbon. See enclosed photo. Currently, this is how we switch input to the 3 output: Center hung - Output1....program output Fascia Ribbon - Output2..manually select input or shortcut key Under belly - External2..manually select input or shortcut key The 3 screen has different content but with the same theme. Say sponsor A: Output1 - advertisement A1 Output2 - advertisement A2 External -advertisement A3 So when sponsor A play.....all 3 advertisement(A1, A2 n A3) goes to the output. We used shortcut key to change the output. Now we have 5 sponsor....need to create 5 of the above. 5 shortcut key. Question....is there somehow we can create a playlist or script to loop the 5 sponsors for 3 outputs? Appreciate you help. Thank you in advance. mazlani attached the following image(s):  Insitu_RibbonFascia.jpg (428kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
