No audio from desktop captures
Joined: 10/31/2017(UTC) Posts: 26  Location: Marina del Rey, CA Thanks: 2 times
I'm trying to integrate a zoom call into my mix that is running on the same computer. I also bring in my iPad from time to time. Any time I do this, there is no audio, and no ability to even turn ON audio. There must be a simple way to do that that I'm missing, but I can't find anything in the "input" section that seems to apply to this.
What am I missing?
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
This seemed to be answered in posts #5 & #6 when the question was previously asked here. Did you try enabling/using the "Stereo Mix" audio recording device, or using a Virtual Audio Cable?
zenvideo wrote:This seemed to be answered in posts #5 & #6 when the question was previously asked here. Did you try enabling/using the "Stereo Mix" audio recording device, or using a Virtual Audio Cable? I did try the stereo audio mix, but not the virtual cable, which I think will probably be my answer. Thanks!
