bobdoyle
#1 Posted : Sunday, November 12, 2017 10:59:39 AM(UTC)
bobdoyle
I'm trying to integrate a zoom call into my mix that is running on the same computer. I also bring in my iPad from time to time. Any time I do this, there is no audio, and no ability to even turn ON audio. There must be a simple way to do that that I'm missing, but I can't find anything in the "input" section that seems to apply to this.
What am I missing?
zenvideo
#2 Posted : Sunday, November 12, 2017 11:18:56 AM(UTC)
zenvideo
This seemed to be answered in posts #5 & #6 when the question was previously asked here. Did you try enabling/using the "Stereo Mix" audio recording device, or using a Virtual Audio Cable?
bobdoyle
#3 Posted : Sunday, November 12, 2017 1:54:20 PM(UTC)
bobdoyle
I did try the stereo audio mix, but not the virtual cable, which I think will probably be my answer. Thanks!
