turn off an overlay whit replay
Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Good evening at all. Someone can explain how to turn off an overlay when sending an "instant replay" or a "video delay". Always if you can. Thank you
Ciao
just use Triggers on your replay inputs
> OnTransitionIn > OverlayInputAllOff
Guillaume
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 69 Location: Canada
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Using the Trigger "OnTransitionIn -> OverlayInputAllOff (or appropriate Overlay) will work Alternatively using a Shortcut key with the same Function will work in any situation (recommended for emergency/panic removal of unwanted Overlays)
vMixGreg
 1 user thanked vmixgreg for this useful post.
Yes, it works. But "Video Delay" when it generates replay to send, does not replicate "triggers setup" in new "inputs", I have to enter them manually for each. On "instant replay" I can not try, I still have to upgrade :-(
You have been a member since:: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
AFAIK you can create a virtual input of the initial one where triggers were configured. This should copy the triggers as well.
Then you can change the input source.
All the best
Marc
