STADIORADIO
#1 Posted : Tuesday, October 17, 2017 1:17:03 PM(UTC)
STADIORADIO
Good evening at all. Someone can explain how to turn off an overlay when sending an "instant replay" or a "video delay". Always if you can. Thank you
#2 Posted : Tuesday, October 17, 2017 1:51:47 PM(UTC)
Ciao
just use Triggers on your replay inputs
> OnTransitionIn > OverlayInputAllOff
Guillaume
STADIORADIO on 10/17/2017(UTC)
vmixgreg
#3 Posted : Tuesday, October 17, 2017 1:54:22 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 19 time(s) in 18 post(s)
Using the Trigger "OnTransitionIn -> OverlayInputAllOff (or appropriate Overlay) will work
Alternatively using a Shortcut key with the same Function will work in any situation (recommended for emergency/panic removal of unwanted Overlays)
vMixGreg
thanks 1 user thanked vmixgreg for this useful post.
STADIORADIO
#4 Posted : Tuesday, October 17, 2017 5:49:19 PM(UTC)
STADIORADIO
Yes, it works. But "Video Delay" when it generates replay to send, does not replicate "triggers setup" in new "inputs", I have to enter them manually for each. On "instant replay" I can not try, I still have to upgrade :-(
STADIORADIO
#5 Posted : Wednesday, October 18, 2017 8:08:34 AM(UTC)
STADIORADIO
is there no solution?
mburel1980
#6 Posted : Wednesday, October 18, 2017 10:00:05 AM(UTC)
mburel1980
Was thanked: 14 time(s) in 12 post(s)
AFAIK you can create a virtual input of the initial one where triggers were configured. This should copy the triggers as well.
Then you can change the input source.
All the best
Marc
STADIORADIO
#7 Posted : Thursday, October 19, 2017 6:48:44 AM(UTC)
STADIORADIO
see video
