bh1054010
#1 Posted : Monday, October 9, 2017 12:06:13 AM(UTC)
bh1054010
I checked the system requiremnts page and it says it only support NVIDIA 960 1060.rather than Nvidia Quadro card?
https://www.vmix.com/sof....aspx#systemrequirements
#2 Posted : Monday, October 9, 2017 5:03:24 AM(UTC)
Hi
this was discussed many times already on the forum. Did you search before posting ?
Technically yes, vMix supports the Quadro M series... But they are not optimized for what vMix needs, so a GeForce GTX gives better performance at a lower price.
The only Quadro that is interesting to use is the P4000 which has more cores than a GTX 1060 but less than a GTX 1070. However it is 3 times more expensive so the only reason to use it is when you need more than 2 simultaneous encodes on the GPU.
Guillaume
