Vmix Does not support quadro m series Card?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Hi
this was discussed many times already on the forum. Did you search before posting ?
Technically yes, vMix supports the Quadro M series... But they are not optimized for what vMix needs, so a GeForce GTX gives better performance at a lower price.
The only Quadro that is interesting to use is the P4000 which has more cores than a GTX 1060 but less than a GTX 1070. However it is 3 times more expensive so the only reason to use it is when you need more than 2 simultaneous encodes on the GPU.
Guillaume
