bambam35614
#1 Posted : Friday, August 2, 2013 6:18:24 AM(UTC)
bambam35614
Is there any way of making 3d zooms for virtual sets
Damn2Good4U
#2 Posted : Friday, August 2, 2013 7:03:55 AM(UTC)
Damn2Good4U
Could you please have a look at this link here http://forums.vmix.com.a....aspx?g=posts&t=1132 it might help
Rottimmy
bambam35614
#3 Posted : Friday, August 2, 2013 7:26:17 AM(UTC)
bambam35614
Rottimmy
this is not relevant to my post! i have made my own virtual set i mean is there anyway to have a 360 degree studio?
AmbotZ
#4 Posted : Friday, August 2, 2013 7:37:06 AM(UTC)
AmbotZ
Was thanked: 22 time(s) in 12 post(s)
This will be a good feature if it is possible or can be added in future release.
If you check config.xml there are only 2 coordinates to move parts/items from virtual set, that's X and Y axis, to complete the 3D space we need the Z axis.
I will try to experiment on this, may be there's a way to add that z axis somewhere in config.xml :)
thanks 1 user thanked AmbotZ for this useful post.
bambam35614 on 8/2/2013(UTC)
markus
#5 Posted : Saturday, August 3, 2013 11:15:23 AM(UTC)
markus
Martin wrote in post no. 57:
Virtual Set XML now supports RotateX, RotateY and RotateZ options for custom sets
Manipulating the z axis should be possible with vMix 10 in config.xml.
Guest (4)
Similar Topics
Stop virtual set's zoom and pan midway! (General Discussion)
by Moblproductions 8/5/2020 12:00:08 PM(UTC)
