Is there any way of making 3d zooms for virtual sets
Joined: 2/26/2013(UTC) Posts: 373 Location: London Thanks: 41 times Was thanked: 37 time(s) in 36 post(s)
this is not relevant to my post! i have made my own virtual set i mean is there anyway to have a 360 degree studio?
Joined: 7/15/2013(UTC) Posts: 35 Location: Philippines
Was thanked: 22 time(s) in 12 post(s)
bambam35614 wrote:Is there any way of making 3d zooms for virtual sets This will be a good feature if it is possible or can be added in future release. If you check config.xml there are only 2 coordinates to move parts/items from virtual set, that's X and Y axis, to complete the 3D space we need the Z axis. I will try to experiment on this, may be there's a way to add that z axis somewhere in config.xml :)
1 user thanked AmbotZ for this useful post.
Quote:If you check config.xml there are only 2 coordinates to move parts/items from virtual set, that's X and Y axis, to complete the 3D space we need the Z axis. Martin wrote in post no. 57: Quote:Virtual Set XML now supports RotateX, RotateY and RotateZ options for custom sets Manipulating the z axis should be possible with vMix 10 in config.xml.
