spencerm24
#1 Posted : Saturday, September 23, 2017 1:14:24 PM(UTC)
spencerm24
I did a search on these forums to hopefully find my answer, but was unable to
Is there a way to edit clips before they're used in a broadcast? Say to create a subclip or remove some off the top of the clip or end?
jvphobic
#2 Posted : Saturday, September 23, 2017 1:16:33 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
If you have the video in the preview pane, you can right click and choose a mark-in and a mark-out point. They are the little green and red dots near the start and finish.
I don't know what you mean by a sub-clip exactly.
spencerm24
#3 Posted : Saturday, September 23, 2017 1:23:56 PM(UTC)
spencerm24
sub clip as in say an editor gives you a clip thats 1 minute long, and you want to take a snip from the middle, say 0:20-0:40 and make it its own clip so you can quickly load it and use it during a broadcast.
