Editing Clips before use in broadcast?
I did a search on these forums to hopefully find my answer, but was unable to
Is there a way to edit clips before they're used in a broadcast? Say to create a subclip or remove some off the top of the clip or end?
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
spencerm24 wrote:I did a search on these forums to hopefully find my answer, but was unable to
Is there a way to edit clips before they're used in a broadcast? Say to create a subclip or remove some off the top of the clip or end? If you have the video in the preview pane, you can right click and choose a mark-in and a mark-out point. They are the little green and red dots near the start and finish. I don't know what you mean by a sub-clip exactly.
sub clip as in say an editor gives you a clip thats 1 minute long, and you want to take a snip from the middle, say 0:20-0:40 and make it its own clip so you can quickly load it and use it during a broadcast.
