bambam35614
#1 Posted : 12 years ago
bambam35614
Is there anyway on Vmix that you can use an autocue
thanks
AmbotZ
#2 Posted : 12 years ago
AmbotZ
Was thanked: 22 time(s) in 12 post(s)
Hi, You can load all your inputs then set-up a playlist.
There's a Playlist button at the bottom.
thanks 1 user thanked AmbotZ for this useful post.
bambam35614 on 8/2/2013(UTC)
paulmeheux
#3 Posted : 12 years ago
paulmeheux
I have used a Dsan autocue.
you have to set up shortcuts for each input and link them.
It would be great if you could set it to just change the output screen but I havent worked out how to yet!
