Is there anyway on Vmix that you can use an autocue
thanks
Joined: 7/15/2013(UTC) Posts: 35 Location: Philippines
Was thanked: 22 time(s) in 12 post(s)
Hi, You can load all your inputs then set-up a playlist. There's a Playlist button at the bottom.
 1 user thanked AmbotZ for this useful post.
Joined: 3/12/2013(UTC) Posts: 7   Location: London Thanks: 1 times
I have used a Dsan autocue. you have to set up shortcuts for each input and link them. It would be great if you could set it to just change the output screen but I havent worked out how to yet!
