video review sl
#1 Posted : Tuesday, September 19, 2017 1:29:40 PM(UTC)
video review sl
Adobe Connect doesn't support standard resolution and frame rates and doesn't work well with vMix.
Below are sources but basically I would like vMix to be able to downconvert standard 1080 & 720 30/60P HD signals to 480 20P.
https://blogs.adobe.com/...nput-resolution-options/
Resolution Frames/sec Video Compression %
High 640×480 20 90
Standard 320×240 10 80
Medium 320×240 8 75
Low 160×120 4 70
For the 16:9 aspect ratio, the settings are the same as their 4:3 counterparts. For example, if 4:3 resolution for any quality setting is 320×240, then its 16:9 counterpart will always be 427×240.
214×120
427×240
854×480
mjgraves
#2 Posted : Wednesday, September 20, 2017 7:42:05 PM(UTC)
mjgraves
In dealing with Adobe Connect are you streaming directly to a server? Or merely emulating a webcam to the Adobe client?
