Feature Requests
Adobe Connect support - 480 20P
Adobe Connect doesn't support standard resolution and frame rates and doesn't work well with vMix. Below are sources but basically I would like vMix to be able to downconvert standard 1080 & 720 30/60P HD signals to 480 20P. https://blogs.adobe.com/...nput-resolution-options/Resolution Frames/sec Video Compression % High 640×480 20 90 Standard 320×240 10 80 Medium 320×240 8 75 Low 160×120 4 70 For the 16:9 aspect ratio, the settings are the same as their 4:3 counterparts. For example, if 4:3 resolution for any quality setting is 320×240, then its 16:9 counterpart will always be 427×240. 214×120 427×240 854×480
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
In dealing with Adobe Connect are you streaming directly to a server? Or merely emulating a webcam to the Adobe client?
Feature Requests
