Loop Through Lower Third/Titles
Good morning everyone!
Hope your day is going well! Is it possible to cycle/loop through several titles/lower thirds? We have several lower thirds/titles that we use everytime we go live. We want to try and automate this process so that we can free up a member of our A/V team. Our titles are either lone images, or images with text on them with the Title Designer.
Is this possible?
TIA.
Joined: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
Depends on when you need the titles to be active.
You can use triggers on a camera if the title is dependent on this, otherwise if it is time based, each having a specific time it must be active, you can perhaps look into the Playlist feature/module, found in the bottom of the main window, next to the streaming module. This can be set up to rotate through titles.
Joined: 4/10/2016(UTC) Posts: 29  Location: Florida, USA Was thanked: 3 time(s) in 3 post(s)
truevineministries wrote:Good morning everyone!
Is this possible?
TIA.
Have you looked at the Data Source functionality? You'd be stuck with same title graphic background, but you can set it to switch sequentially, the title info.
