truevineministries
#1 Posted : Monday, September 18, 2017 10:10:10 AM(UTC)
truevineministries
Good morning everyone!
Hope your day is going well! Is it possible to cycle/loop through several titles/lower thirds? We have several lower thirds/titles that we use everytime we go live. We want to try and automate this process so that we can free up a member of our A/V team. Our titles are either lone images, or images with text on them with the Title Designer.
Is this possible?
TIA.
stigaard
#2 Posted : Monday, September 18, 2017 4:08:07 PM(UTC)
stigaard
Denmark
Depends on when you need the titles to be active.
You can use triggers on a camera if the title is dependent on this, otherwise if it is time based, each having a specific time it must be active, you can perhaps look into the Playlist feature/module, found in the bottom of the main window, next to the streaming module. This can be set up to rotate through titles.
Curt M
#3 Posted : Monday, September 18, 2017 4:21:34 PM(UTC)
Curt M
Is this possible?
TIA.
Have you looked at the Data Source functionality?
You'd be stuck with same title graphic background, but you can set it to switch sequentially, the title info.
