kol0
#1 Posted : Saturday, September 16, 2017 12:04:15 PM(UTC)
kol0
Was thanked: 8 time(s) in 8 post(s)
Hi
I have problem with adding mono ASIO input. I tested it with zoom H6.
Video with crash:
Clean Vmix. When i add mono asio input vmix crash.
But when i restart vmix. Add stereo input, close it, and add mono it works.
I have presets with mono inputs from version 19 and when i loading them vmix crash. :(
Code:
Opis:
  Stopped working
Podpis problemu:
  Nazwa zdarzenia problemu:	APPCRASH
  Application Name:	vMix64.exe
  Application Version:	20.0.0.27
  Application Timestamp:	59affb7d
  Fault Module Name:	bassasio.dll
  Fault Module Version:	1.3.1.0
  Fault Module Timestamp:	5491813b
  Exception Code:	c0000005
  Exception Offset:	0000000000003670
  Wersja systemu operacyjnego:	6.3.9600.2.0.0.256.48
  Identyfikator ustawień regionalnych:	1045
#2 Posted : Saturday, September 16, 2017 2:43:10 PM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
This likely means there is an issue with the ASIO driver for the zoom H6.
Check the manufacturer to see if they have an update available.
