Vmix crash bassasio.dll issue
Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
Hi I have problem with adding mono ASIO input. I tested it with zoom H6. Video with crash: Clean Vmix. When i add mono asio input vmix crash. But when i restart vmix. Add stereo input, close it, and add mono it works. I have presets with mono inputs from version 19 and when i loading them vmix crash. :( Code:Opis:
Stopped working
Podpis problemu:
Nazwa zdarzenia problemu: APPCRASH
Application Name: vMix64.exe
Application Version: 20.0.0.27
Application Timestamp: 59affb7d
Fault Module Name: bassasio.dll
Fault Module Version: 1.3.1.0
Fault Module Timestamp: 5491813b
Exception Code: c0000005
Exception Offset: 0000000000003670
Wersja systemu operacyjnego: 6.3.9600.2.0.0.256.48
Identyfikator ustawień regionalnych: 1045
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
This likely means there is an issue with the ASIO driver for the zoom H6. Check the manufacturer to see if they have an update available.
Martin vMix
