atwsportscast
#1 Posted : Saturday, September 16, 2017 10:02:15 AM(UTC)
atwsportscast
on a new upgrade while install I get "Unable to register the DLL/OCX: RegSvr32 failed with exit code 0x3" error.
Also my old version of vmix will not work.
The computer`s OS is Windows 10 Home.
Thanks in advance,
Dean Johnson
#2 Posted : Saturday, September 16, 2017 2:46:53 PM(UTC)
This error means a component in Windows is corrupt unfortunately.
Some things you can try:
1. Install latest windows updates
2. Repair system files:
https://www.howtogeek.co...e-sfc-and-dism-commands/
3. if all else fails, windows will need to be reinstalled.
xaver
#3 Posted : Thursday, November 30, 2017 4:10:23 PM(UTC)
xaver
Had the same issue on a Windows 10 64bit OS
deinstalled all of the "Visual C++ 2010 Redistributable Package" and the error was gone!
