"Unable to register the DLL/OCX: RegSvr32 failed with exit code 0x3". problem
Joined: 3/6/2010(UTC) Posts: 17  Location: columbia. tn Was thanked: 1 time(s) in 1 post(s)
on a new upgrade while install I get "Unable to register the DLL/OCX: RegSvr32 failed with exit code 0x3" error.
Also my old version of vmix will not work.
The computer`s OS is Windows 10 Home.
Thanks in advance, Dean Johnson
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Hi, This error means a component in Windows is corrupt unfortunately. Some things you can try: 1. Install latest windows updates 2. Repair system files: https://www.howtogeek.co...e-sfc-and-dism-commands/3. if all else fails, windows will need to be reinstalled. Regards, Martin vMix
Had the same issue on a Windows 10 64bit OS
deinstalled all of the "Visual C++ 2010 Redistributable Package" and the error was gone!
