Systems
3GB vs 6GB GDDR5
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
Hi guys, I want to put my own system together and I'm having trouble deciding on a GFX card.
I want to get a GTX1060 but the price of the 6GB version is nearly half as much again in price.
Is the extra vram worth the cost?
I'm planing on using between 4 and 6 1080 cams, recording, streaming and VT playback.
Joined: 5/31/2017(UTC) Posts: 15 Location: Murray, KY
This came up in one of the Fun Time Live shows, Martin suggested the 6GB 1060 would be beneficial for vMix and inputs if I'm recalling it correctly. For your setup, I'd do the 6GB 1060 just based on what you are planning to do. Go big or go home, right? If it helps look up the card on pcpartpicker.com to find the best price. The EVGA 1060 6GB Superclocked appears to be the fastest version from any of the vendors. However both the 3 and 6GB benchmark fairly close.
RHSportable wrote:This came up in one of the Fun Time Live shows, Martin suggested the 6GB 1060 would be beneficial for vMix and inputs if I'm recalling it correctly. For your setup, I'd do the 6GB 1060 just based on what you are planning to do. Go big or go home, right? If it helps look up the card on pcpartpicker.com to find the best price. The EVGA 1060 6GB Superclocked appears to be the fastest version from any of the vendors. However both the 3 and 6GB benchmark fairly close. Thanks for the reply, maybe I'll see if there are a few more pennies down the couch cushions ;)
Systems
3GB vs 6GB GDDR5
