Unable to dream to facebook
Joined: 5/4/2016(UTC) Posts: 28 Location: Portland, Or
I know there are a ton of I can’t stream to Facebook threads and everything I am seeing is about the change from only being able to do multiple destinations with Facebook. My issue is I can’t stream to Facebook even when it’s the only destination. I input the Facebook setting, login as I have done several times before but when I go to stream it says I need to set it up. I have tried multiple pages to stream as destinations. I have reset the computer, used new and existing setups but none will let me stream to Facebook. Any other suggestions? I can stream to other CDN’s just not Facebook. I am running vmix 19.0.0.47. Thanks File Attachment(s):  image.jpg (3,331kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
@ Potimus
Update to 19.0.0.54 and see if that resolves the issue.
IceStream wrote:@ Potimus
I was trying to avoid that so I could continue to stream to Facebook and others at the same time.
