Potimus
#1 Posted : Wednesday, August 23, 2017 8:31:47 PM(UTC)
Potimus
I know there are a ton of I can’t stream to Facebook threads and everything I am seeing is about the change from only being able to do multiple destinations with Facebook. My issue is I can’t stream to Facebook even when it’s the only destination. I input the Facebook setting, login as I have done several times before but when I go to stream it says I need to set it up. I have tried multiple pages to stream as destinations. I have reset the computer, used new and existing setups but none will let me stream to Facebook. Any other suggestions? I can stream to other CDN’s just not Facebook.
I am running vmix 19.0.0.47.
File Attachment(s):
#2 Posted : Wednesday, August 23, 2017 9:40:53 PM(UTC)
@ Potimus
Update to 19.0.0.54 and see if that resolves the issue.
Potimus
#3 Posted : Wednesday, August 23, 2017 9:54:01 PM(UTC)
Potimus
IceStream wrote:
@ Potimus
I was trying to avoid that so I could continue to stream to Facebook and others at the same time.
