HD crash - where are shortcut preferences stored?
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
Hi, so everything was going so well, then my HD crashed, now the Win10 install wont boot, I can see the data, and have installed Vmix elsewhere, but all my MIDI shortcuts are gone. I have opened the preset okay and relocated the files I ineed for it. But the MIDI Shortcuts I spent considerable time setting up are not loaded in the preset files I guess. Where are these stored? I can access the data on the old drive so hoping that I can just grab the configuration files and put them in the right place.
Many thanks
It could be about anywhere on your system. I just brought up a new VMix session, went to export the midi shortcuts and it went to the folder where I last saved something in Windows. Try searching for .config file types and see if Windows files Manager can find them.
Yeah I guess, but maybe someone knows! Thanks anyhow, tried copying the programs/vmix/shortcuts folder but not in there....
As it happens, I was able to repair the drive, but I did find the location of the vMix shortcuts preferences: /user/AppData/Local/StudioCaost_Pty_Ltd/vMix64.exe_Url_somerandomstring/19.0.54/user.config (where 19.0.x is software version)
 1 user thanked nowski for this useful post.
