nowski
#1 Posted : Tuesday, August 15, 2017 12:35:33 PM(UTC)
nowski
Hi, so everything was going so well, then my HD crashed, now the Win10 install wont boot, I can see the data, and have installed Vmix elsewhere, but all my MIDI shortcuts are gone.
I have opened the preset okay and relocated the files I ineed for it. But the MIDI Shortcuts I spent considerable time setting up are not loaded in the preset files I guess.
Where are these stored? I can access the data on the old drive so hoping that I can just grab the configuration files and put them in the right place.
Many thanks
Mike_in_tX
#2 Posted : Tuesday, August 15, 2017 1:27:36 PM(UTC)
Mike_in_tX
It could be about anywhere on your system. I just brought up a new VMix session, went to export the midi shortcuts and it went to the folder where I last saved something in Windows. Try searching for .config file types and see if Windows files Manager can find them.
nowski
#3 Posted : Tuesday, August 15, 2017 2:06:08 PM(UTC)
nowski
Yeah I guess, but maybe someone knows!
Thanks anyhow, tried copying the programs/vmix/shortcuts folder but not in there....
nowski
#4 Posted : Thursday, August 17, 2017 4:38:15 AM(UTC)
nowski
As it happens, I was able to repair the drive, but I did find the location of the vMix shortcuts preferences:
/user/AppData/Local/StudioCaost_Pty_Ltd/vMix64.exe_Url_somerandomstring/19.0.54/user.config (where 19.0.x is software version)
thanks 1 user thanked nowski for this useful post.
stevespaw on 8/17/2017(UTC)
