nowski
#1 Posted : Sunday, August 13, 2017 12:51:48 PM(UTC)
nowski
As I sit here and endlessly finesse my show preset, It struck me, that I am working on a machine that we will ultimately replace to increase the possibilities with Vmix. So I guess, how do I move my show to a new machine? Is this possible?
I understand that some inputs wont work due to different hardware etc, but all the triggers, overlays, midi mappings etc would be a drag to have to recreate it from scratch.
rudyengels
#2 Posted : Sunday, August 13, 2017 3:46:54 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
On top of vMix you can use the Save option to save your preset. On your new computer use Open and search your saved preset. Copy your used media to the same folders on the new pc.
nowski
#3 Posted : Tuesday, August 15, 2017 4:34:49 AM(UTC)
nowski
Thanks, I knew about saving, just thought I'd read somewhere that you cant move show presets between machines. Glad it will work.
N
