Moving show prests to new machine
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
As I sit here and endlessly finesse my show preset, It struck me, that I am working on a machine that we will ultimately replace to increase the possibilities with Vmix. So I guess, how do I move my show to a new machine? Is this possible? I understand that some inputs wont work due to different hardware etc, but all the triggers, overlays, midi mappings etc would be a drag to have to recreate it from scratch.
Rank:: Advanced Member
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
On top of vMix you can use the Save option to save your preset. On your new computer use Open and search your saved preset. Copy your used media to the same folders on the new pc.
Thanks, I knew about saving, just thought I'd read somewhere that you cant move show presets between machines. Glad it will work.
N
