mahdi87_gh
#1 Posted : Monday, July 31, 2017 9:10:29 AM(UTC)
mahdi87_gh
Views messages in topic : 2
I have multiple RTMP live streams as input. When a stream stops and starts again after a few secs, my input will remain freezed. If I right click on it and press "Reset", it'll start playing again. But the problem is it should be done automatically. I have found a way to detect stop/start of my streams but the function "Restart" won't reset the input. Is there another API function for it?
kjones9999
#2 Posted : Monday, July 31, 2017 6:06:49 PM(UTC)
kjones9999
Out of curiosity, how are you automatically detecting it?
mahdi87_gh
#3 Posted : Tuesday, August 1, 2017 12:07:24 AM(UTC)
mahdi87_gh
I have used ffprobe to check whether rtmp stream is alive or not. If it's back alive, sending http request to vmix api would be easy to do. I have wrote a C# program for this.
By he way is it possible to reset input by API functions? or scripts?
