What is the function to reset an input
Hi, I have multiple RTMP live streams as input. When a stream stops and starts again after a few secs, my input will remain freezed. If I right click on it and press "Reset", it'll start playing again. But the problem is it should be done automatically. I have found a way to detect stop/start of my streams but the function "Restart" won't reset the input. Is there another API function for it? Thanks
Thanks: 29 times Was thanked: 79 time(s) in 50 post(s)
Out of curiosity, how are you automatically detecting it?
I have used ffprobe to check whether rtmp stream is alive or not. If it's back alive, sending http request to vmix api would be easy to do. I have wrote a C# program for this. By he way is it possible to reset input by API functions? or scripts?
