michaelrb
#1 Posted : Friday, July 28, 2017 9:58:23 AM(UTC)
michaelrb
Sorry to sound like the Newbee I am, but I was told to change an audio setting to Mainboard audio. I'm not sure what that means.
Here is a screen shot of available settings. Default for new is set to master.
michaelrb attached the following image(s):
michaelrb
#2 Posted : Friday, July 28, 2017 10:03:08 AM(UTC)
michaelrb
Here is the original suggestion. (Getting a bluetooth device to be recognized by VMix.
"If you really want to use your Bluetooth interface:
Go to vMix settings --> Audio Outputs and set Bus B to your Mainboard audio.
Route all inputs to send to your caller to Bus B. Do not route the Mackie input to B.
Connect your Mainboard audio output to a stereo line in on the Mackie e.g. channel 5/6.
Set the gain correctly: Page 3 of the Mackie manual.
Mute this channel, leave the fader down, just set the 'Mon' knob to 'U'.
Set the 'Mon' knob on channel 1 (Microphone) to 'U'. Do not turn the 'Mon' knob on channel 3 (Blue Driver), leave it at 0.
Change the cable connected to 'FX Send' to 'Mon Send'. Control the audio level to your caller with the 'Mon' fader."
ovinas
#3 Posted : Saturday, July 29, 2017 12:45:21 AM(UTC)
ovinas
Speakers (Realtek High Definition Audio)
