Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Sorry to sound like the Newbee I am, but I was told to change an audio setting to Mainboard audio. I'm not sure what that means. Here is a screen shot of available settings. Default for new is set to master. michaelrb attached the following image(s):  ScreenShot001.jpg (50kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Here is the original suggestion. (Getting a bluetooth device to be recognized by VMix.
"If you really want to use your Bluetooth interface: Go to vMix settings --> Audio Outputs and set Bus B to your Mainboard audio. Route all inputs to send to your caller to Bus B. Do not route the Mackie input to B. Connect your Mainboard audio output to a stereo line in on the Mackie e.g. channel 5/6. Set the gain correctly: Page 3 of the Mackie manual. Mute this channel, leave the fader down, just set the 'Mon' knob to 'U'. Set the 'Mon' knob on channel 1 (Microphone) to 'U'. Do not turn the 'Mon' knob on channel 3 (Blue Driver), leave it at 0. Change the cable connected to 'FX Send' to 'Mon Send'. Control the audio level to your caller with the 'Mon' fader."
Speakers (Realtek High Definition Audio)
