michaelrb
#1 Posted : Thursday, July 20, 2017 9:20:48 AM(UTC)
michaelrb
It seems the Facebook Streaming Preset can only be used by itself. (You can't stream to another service if you are using your Facebook Preset for Streaming). Can you stream to Facebook AND another service simultaneously if you set up Facebook via a Custom RTMP?
SportsNetUSA.net
#2 Posted : Thursday, July 20, 2017 12:16:05 PM(UTC)
SportsNetUSA.net
michaelrb
#3 Posted : Thursday, July 20, 2017 2:29:03 PM(UTC)
michaelrb
Thanks for the info. On 2 occasions when I started to stream, the stream light stayed yellow, then I got an error that said too full or near to full. Then the stream failed. Is there something I need to tweak?
mjgraves
#4 Posted : Thursday, July 20, 2017 3:55:33 PM(UTC)
mjgraves
According to the PTZ Optics folks, you can stream to FB and other services if you don't use their API. That means crafting a custom RTMP target instead.
They claimed to be doing that last week.
They had a 720 stream on FB while their YouTube channel has the 1080p sversion.
