Streaming Facebook and Periscope Simultaneoulsy
Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
It seems the Facebook Streaming Preset can only be used by itself. (You can't stream to another service if you are using your Facebook Preset for Streaming). Can you stream to Facebook AND another service simultaneously if you set up Facebook via a Custom RTMP?
You have been a member since:: 10/7/2015(UTC) Posts: 635 Location: California
Thanks for the info. On 2 occasions when I started to stream, the stream light stayed yellow, then I got an error that said too full or near to full. Then the stream failed. Is there something I need to tweak?
According to the PTZ Optics folks, you can stream to FB and other services if you don't use their API. That means crafting a custom RTMP target instead. They claimed to be doing that last week. They had a 720 stream on FB while their YouTube channel has the 1080p sversion.
