andy2020
#1 Posted : Wednesday, July 5, 2017 10:03:16 AM(UTC)
andy2020
Hi I am looking at the Magewell XI400DE capture card and was wondering if anybody has had issues with it or would recommend an alternative?
Cheers in advance.
zenvideo
#2 Posted : Thursday, July 6, 2017 2:32:09 PM(UTC)
zenvideo
Aside from the fact that the XI400DE is a "gen-1" product which has been discontinued and replaced by the Pro Capture (gen-2) version, it will still work fine with vMix. However, if there's a chance of getting the Pro Capture Quad input version, I'd suggest that's a better option. Other alternatives you might want to look at are the Blackmagic Decklink Duo/Quad 2 cards.
PFBM on 7/6/2017(UTC)
Similar Topics
most stable SDI capture card (Hardware Compatibility)
by konstantinos 1/8/2026 9:47:51 AM(UTC)
Active Silicon Phoenix PE4 HDSDI Capture Card (D20HDSDI-pe4) (Hardware Compatibility)
by neckro 6/13/2020 4:11:27 AM(UTC)
blackmagic decklink sdi capture cards (Feature Requests)
by francolombardi 4/27/2020 10:46:42 PM(UTC)
Nvidia Quadro SDI Capture Card (Hardware Compatibility)
by Joeboe 6/9/2019 8:17:23 AM(UTC)
What's the best 4x HDMI or SDI capture card under $1K? - early 2019 (Hardware Compatibility)
by mmorlan62 3/16/2019 2:30:27 AM(UTC)
What's the best 4x HDMI or SDI capture card for 2019? (Hardware Compatibility)
by mmorlan62 3/16/2019 2:23:21 AM(UTC)
Best quad SDI capture card (Hardware Compatibility)
by JW 3/3/2018 2:11:46 PM(UTC)
Magewell Eco Quad SDI capture card. Need Help (Hardware Compatibility)
Belarus Nick Davidson 11/27/2017 11:53:29 PM(UTC)
Geovision GV-SDI-204 - $450 4ch HD-SDI capture card (Hardware Compatibility)
by Jackster 8/3/2014 8:14:06 PM(UTC)
analog or SDI capture Card (Hardware Compatibility)
by nandhitv 6/10/2014 2:06:34 PM(UTC)
external SDI Capture Card (General Discussion)
by jerome 8/30/2012 9:04:39 AM(UTC)
