NDI
ndi not working in adobe after effects and premier pro
i installed adobe ndi plugin from website but in my adobe after effect and adobe premier pro it dosnt shows ndi monitor in settings ..
afriaazz wrote:i installed adobe ndi plugin from website but in my adobe after effect and adobe premier pro it dosnt shows ndi monitor in settings .. Are you saying the settings in Adobe product or NDI Monitor? You post doesn't make it clear what application you are looking at? In Adobe Premiere, you need to go to the 'Edit' menu, then 'Preferences' finally, choose 'Playback' settings. In that window, you will check the 'NewTek NDI Output' in both the Video and Audio devices areas. For After Effects, the plug-in is automatic and shouldn't require any setup, but you might need to 'scrub' the timeline a frame or two to get it started outputting content. Kane Peterson NewTek
yea i Mean in Adobe Product ...... In Adobe Premiere, you need to go to the 'Edit' menu, then 'Preferences' finally, choose 'Playback' settings. In that window, there is no 'NewTek NDI Output' options
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Are you using Adobe Creative Cloud or an older version of Adobe Premiere? It only works with Adobe Creative Cloud.
Originally Posted by: afriaazz  yea i Mean in Adobe Product ...... In Adobe Premiere, you need to go to the 'Edit' menu, then 'Preferences' finally, choose 'Playback' settings. In that window, there is no 'NewTek NDI Output' options
for us it is the same. In two PCs no NDI Output available with after effects 2022 and NDI tools 5 under Playback preferences.
NDI
